[b][b][b][b] #[b]5 (permalink)
07 Apr 2007, 03:09 pm[/b][/b][/b][/b][/b] |
[size=13][size=13][size=13] [/size][/size][/size] | [size=13][size=13][size=13][size=19]skylight  Administrator[/size][/size][/size][/size] | | [size=13][size=13][size=13][size=11]Join Date: Jul 2001 Posts: 1,314 skylight's Gallery [/size][/size][/size][/size] |
[size=13][size=13][size=13][size=13][size=11] Re: Error Code List
[/size] [/size] [/size] [/size] [/size]
[size]
P1031 HO2S Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1 P1032 HO2S Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1 P1105 Secondary Vacuum Sensor Circuit P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermitten P1108 BARO to MAP Sensor Comparison Too High P1109 Secondary Port Throttle System P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage P1113 Intake Resonance Switchover Solenoid Control Circuit P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage P1116 ECT Signal Unstable or Intermittent P1117 Engine Coolant Temp. Signal Out-Of-Range Low P1118 Engine Coolant Temp. Signal Out-Of-Range High P1119 ECT Signal Out-Of-Range With TFT Sensor P1120 Throttle Position (TP) Sensor 1 Circuit P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage P1125 APP System P1130 HO2S Circuit Low Variance Bank 1 Sensor 1 P1131 HO2S Circuit Low Variance Bank 1 Sensor 2 P1132 HO2S Circuit Low Variance Bank 2 Sensor 1 P1133 HO2S Insufficient Switching Bank 1 Sensor 1 P1134 HO2S Transition Time Ratio Bank 1 Sensor 1 P1135 HO2S Lean Mean Bank 1 Sensor 1 P1136 HO2S Rich Mean Bank 1 Sensor 1 P1137 HO2S Bank 1 Sensor 2 Lean System or Low Voltage P1138 HO2S Bank 1 Sensor 2 Rich or High Voltage P1139 HO2S Insuff. Switching Bank 1 Sensor 2 P1140 HO2S Transition Time Ratio Bank 1 Sensor 2 P1141 HO2S Heater Control Circuit Bank 1 Sensor 2 P1143 HO2S Bank 1 Sensor 3 Lean System or Low Voltage P1144 HO2S Bank 1 Sensor 3 Rich or High Voltage P1145 HO2S Cross Counts Bank 1 Sensor 3 P1153 HO2S Insufficient Switching Bank 2 Sensor 1 P1154 HO2S Transition Time Ratio Bank 2 Sensor 1 P1155 HO2S Lean Mean Bank 2 Sensor 1 P1156 HO2S Rich Mean Bank 2 Sensor 1 P1157 HO2S Bank 2 Sensor 2 Lean System or Low Voltage P1158 HO2S Bank 2 Sensor 2 Rich or High Voltage P1159 HO2S Cross Counts Bank 2 Sensor 2 P1161 HO2S Heater Control Circuit Bank 2 Sensor 2 P1163 HO2S Bank 2 Sensor 3 Lean System or Low Voltage P1164 HO2S Bank 2 Sensor 3 Rich or High Voltage P1165 HO2S Cross Counts Bank 2 Sensor 3 P1170 Bank to Bank Fuel TrimOffset P1171 Fuel System Lean During Acceleration P1172 Fuel Transfer Pump Flow Insufficient P1185 Engine Oil Temperature Circuit P1186 EOT Circuit Performance P1187 EOT Sensor Ckt. Low Voltage P1188 EOT Sensor Ckt. High Voltage P1189 Engine Oil Pressure (EOP) Switch Circuit P1190 Engine Vacuum Leak P1191 Intake Air Duct Air Leak P1200 Injector Control Circuit P1201 (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance P1202 (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency P1203 (Alt. Fuel) Gas Mass Sensor Circuit High Frequency P1211 Mass Air Flow Circuit Intermittent High P1212 Mass Air Flow Circuit Intermittent Low P1214 Injection Pump Timing Offset P1215 Ground Fault Detection Indicated P1216 Fuel Solenoid Response Time Too Short P1217 Fuel Solenoid Response Time Too Long P1218 Injection Pump Calibration Circuit P1219 Throttle Position Sensor Reference Voltage P1220 Throttle Position (TP) Sensor 2 Circuit P1221 Fuel Pump Secondary Circuit Low P1222 Injector Control Circuit Intermittent P1225 Injector Circuit Cylinder 2 Intermittent P1228 Injector Circuit Cylinder 3 Intermittent P1231 Injector Circuit Cylinder 4 Intermittent P1234 Injector Circuit Cylinder 5 Intermittent P1237 Injector Circuit Cylinder 6 Intermittent P1240 Injector Circuit Cylinder 7 Intermittent P1243 Injector Circuit Cylinder 8 Intermittent P1245 Intake Plenum Switchover Valve P1250 Early Fuel Evaporation Heater Circuit P1257 Supercharger System Overboost P1258 Engine Coolant Overtemperature - Protection Mode Active P1260 Last Test Failed Failed SCC ENTER:More Info. P1270 Accelerator Pedal Position Sensor A/D Converter Error P1271 Accelerator Pedal Position (APP) Sensor 1-2 Correlation P1272 Accelerator Pedal Position Sensor 2 P1273 "Accelerator Pedal Position Sensor 1 P1274 Injectors Wired Incorrectly P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit P1276 Accelerator Pedal Position Sensor 1 Circuit Performance P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit P1281 Accelerator Pedal Position Sensor 2 Circuit Performance P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage P1285 Accelerator Pedal Position Sensor 3 Circuit P1286 Accelerator Pedal Position Sensor 3 Circuit Performance P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage P1300 Ignitor Circuit P1305 Ignition Coil 2 Primary Feedback Circuit P1310 Ignition Coil 3 Primary Feedback Circuit P1315 Ignition Coil 4 Primary Feedback Circuit P1320 IC 4X Reference Circuit Intermittent P1321 Electronic Ignition System Fault Line P1322 EI System or Ignition Control Extra or Missing P1323 IC 24X Reference Circuit Low Frequency P1324 Crank RPM Too Low P1335 CKP Circuit P1336 Crankshaft Position (CKP) System Variation Not Learned P1345 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation P1346 Intake Camshaft Position [CMP] Sensor System Performance P1350 Ignition Control System P1351 Ignition Coil Control Circuit High Voltage P1352 IC Output High/Pulse Detected when GND_Cyl. 2 P1353 IC Output High/Pulse Detected when GND_Cyl. 3 P1354 IC Output High/Pulse Detected when GND_Cyl. 4 P1355 IC Output High/Pulse Detected when GND_Cyl. 5 P1356 IC Output High/Pulse Detected when GND_Cyl. 6 P1357 IC Output High/Pulse Detected when GND_Cyl. 7 P1358 IC Output High/Pulse Detected when GND_Cyl. 8 P1359 Ignition Coil Group 1 Control Circuit P1360 Ignition Coil Group 2 Control Circuit P1361 Ignition Coil Control Circuit Low Voltage P1362 IC Cylinder 2 Not Toggling After Enable P1363 IC Cylinder 3 Not Toggling After Enable P1364 IC Cylinder 4 Not Toggling After Enable P1365 IC Cylinder 5 Not Toggling After Enable P1366 IC Cylinder 6 Not Toggling After Enable P1367 IC Cylinder 7 Not Toggling After Enable P1368 IC Cylinder 8 Not Toggling After Enable P1370 IC 4X Reference Circuit Too Many Pulses P1371 IC 4X Reference Circuit Too Few Pulses P1372 Crankshaft Position (CKP) Sensor A-B Correlation P1374 3X Reference Circuit P1375 IC 24X Reference Circuit High Voltage P1376 Ignition Ground Circuit P1377 IC Cam Pulse To 4X Reference Pulse P1380 Misfire Detected - Rough Road Data Not Available P1381 Misfire Detected - No Communication with Brake Control Module P1390 Wheel Speed Sensor 1 - G - Sensor Circuit P1391 Wheel Speed Sensor 1 - G - Sensor Circuit Performance P1392 Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage P1393 Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage P1394 Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent P1395 Wheel Speed Sensor 2 - G - Sensor Circuit P1396 Wheel Speed Sensor 2 - G - Sensor Circuit Performance P1397 Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage P1398 Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage P1399 Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent P1403 Exhaust Gas Recirculation System Valve 1 P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance P1405 Exhaust Gas Recirculation System Valve 3 P1406 EGR Valve Pintle Position Circuit P1407 EGR Air Intrusion in Exhaust Supply to EGR Valve P1408 Intake Manifold Pressure Sensor Circuit P1409 EGR Vacuum System Leak P1410 Fuel Tank Pressure System P1415 Secondary Air Injection (AIR) System Bank 1 P1416 Secondary Air Injection (AIR) System Bank 2 P1418 Secondary Air Injection System Relay A Control Circuit High P1420 Intake Air Low Pressure Switch Circuit Low Voltage P1421 Intake Air Low Pressure Switch Circuit High Voltage P1423 Intake Air High Pressure Switch Circuit High Voltage P1431 Fuel Level Sensor 2 Circuit Performance P1432 Fuel Level Sensor 2 Circuit Low Voltage P1433 Fuel Level Sensor 2 Circuit High Voltage P1441 Evaporative Emission (EVAP) System Flow During Non-Purge P1442 EVAP Vacuum Sw. High Voltage During Ign. On P1450 Barometric Pressure Sensor Circuit P1451 Barometric Press. Sensor Performance P1460 Cooling Fan Control System P1460 Misfire Detected With Low Fuel Level P1480 Cooling Fan 1 Control Circuit High P1483 Engine Cooling System Performance
[/size]
Share
[url=http://twitter.com/home?status=Error+Code+List http%3A%2F%2Fwww.ptcruiserlinks.com%2Fforum%2Fgeneral-turbo-discussions%2F14334-error-code-list.html%23post212913][/url]
[size]
Axel likes this. __________________ PT Cruiser
 [/size] |
